tsmith5411
- Mar 24, 2023
I have a router with a Fanuc 21i-M control and I am trying to drip feed programs using ProNC software. I am using an RS232 cable to communicate; 9 pin at the PC and 25 pin at the Fanuc. I can transfer files to the Fanuc memory without issue but I continue to get an 087 Buffer Overflow alarm when drip feeding programs too large for the Fanuc memory. It will run roughly 30% of the program until the buffer becomes too full and then it triggers the 087 alarm. I have slowed baud rate to 4800 and turned off FIFO buffers after reading that suggestion in other posts. I was able to add data packet delays and character delays which gave me a round-about way to run the program but it is not a sustainable solution. I believe my true issue is with the Xon/Xoff handshake. I have Xon/Xoff set as my flow control on the ProNC software and on the COM port in the device manager on my PC. I believe that the Fanuc is not sending an Xoff signal or maybe my PC is not recognizing it. Is there a way to test the handshake or a solution to my drip feed issue? Any help is appreciated. Thanks.
