Turntech
- Sep 29, 2015
- Ottawa, Ontario
Hi All,
Been lurking around the board searching for answers to this to no avail so figure I may as well ask. I'm sure that someone here has made adjustments to their G61.1 settings on a Meldas control.
I just installed a basically new old stock 1998 Feeler FV800 with a Mistubishi Meldas 520AMR control. Everything is running great other than a bit of corner gouging above 40IPM. I turned on the G61.1 accuracy mode which solved the issue but the Accel./Decel. rates appear to have never been tweaked in my control and are therefore very slow (about 20ipm around a .250 rad).
Attached are photos of my current settings screen and the parameter functions in the manual. Unfortunately the manual is not much help explaining the functions of F1-8, FM1/2 or the K factor... was thinking of inputting the values used in the manual example in the top right as a start but without knowing what the values affect, I will not be able to tune it very well.
Anyone have experience with these older Meldas's and setting these param's for G61.1?
Cheers
Cheers
