Hey guys, my first post on here. I have a Haas tl 2 from 2005 at work, im trying to get them to let me do some machining as i got certified back in highschool. This lathe is giving me a bunch of problems, first is that if you are doing a taper or circular interpolation you need to put the z before the x or it sends your toolpath everywhere but where it needs to be. Second is my contour works fine by itself or under the g70 cycle but in graphics on the g71 it turns into a nightmare my code is this
T101
M06 s2000
G00 z.01 x1.5
G71 p1 q2 d.1 u.05 w.05 f.01
N1 G00 w0 x1.5
G01 z0 x0
G03 z-.25 x.5 r.25
G01 z-.875
G02 z1 x.625 r.125
G01 z-1.75 x.75
G01 z-2 x1
N2 G01 z-3
It has been a while and it ran almost perfectly until it hit the first rough cut on the .25 radius then the toolpatb got sent through the part every which way. Any help would be much appreciated, I've heard a lot of people say that Haas is very picky about codes. This code also worked completely fine in a Cnc simulator program.
T101
M06 s2000
G00 z.01 x1.5
N1 G00 w0 x1.5
G01 z0 x0
G03 z-.25 x.5 r.25
G01 z-.875
G02 z1 x.625 r.125
G01 z-1.75 x.75
G01 z-2 x1
N2 G01 z-3
