Hi,
Its some time sense I wrote anything :-) ... I have reconditioned our 1980 Graziano SAG 12S and
in general it works nice.
There is something that bothers me and finally I found the cause... the cross slide lead screw is warn at
the far end and has about 0.15 play. This is annoying and effects the surface finish..
After checking I see that if I drag the half nut close to me there is almost ZERO play. This tells me that
the half nut is OK and only the tread is warn out. I was planing to purchase a trapezoid left hand thread rod
and match it with the rest of the cross slide shaft...
The problem is that a TR20 with 5mm pitch is none standard .. Any ideas were to get it ?
Secondly anyone knows if the original thread is ACME 29 degrees or ISO 30 degrees ?
Thanks,
Noam.
Thanks,
Noam.
