MainelyIan
- Apr 7, 2024
- 04294
So I have been working on disassembly of a lathe I purchased a few months ago. I have not used it other than to turn a few bits of metal into smaller bits of metal. I am new to lathes and machining as a whole other than a Seig X2 mini mill that I have converted to CNC using 3d printed parts and am slowly machining the parts in aluminum to replace the 3d printed parts.
While trying to take apart the cross slide screw I was unable to remove the bushing that screws into the cross slide. I put the small nut back on (to protect the threads). And tapped with a hammer. The nut was not on far enough and I damaged the threads on the screw and in the nut.
So my question is. What is the best way to fix this,
1 weld on additional material and machine down and rethread.
2 Cut off threaded part, drill and tap and add a thread (bolt)
3 Cut off threaded part, drill a hole add a peice of metal and thread the new peice.
As I said above very new to machining (especially on a lathe). Any advice would be appreciated. The last option was to get a new screw but I am unable to find one (small dial no taper attachment).
