storrings
- Feb 5, 2024
- Timmins, Ontario
I'm trying to set up a TRT100 on a TM-2P. The rotary table is already installed but needs to be calibrated. When I run the MRZP trunnion calibration I get the following error:
I've tried manually setting the A-axis limit. It's zero by default. I've set it to -90 manually. Same error. Also, by setting it to -90 (only negative values allowed), it rotates the platter from 0 to 90 away from the user (see below). I can't find a way to limit it from zero to 90 the other way.
Any help would be appreciated.
Thanks.
Thanks.
