Dave.Phillips
- May 20, 2023
Hi Irby!I measure the gib screws on both my 7" and 9" swing bottom cross slides as .182" x 36. That's somewhere between a #8 (.164) and a #10 (.190) screw. And .182" is 4.62mm. So what did Hardinge use, an on-the-small size #10???
Irby
I don't know... I'm not home at the moment however the OD was a perfect fit for a 5mm with the exception of the threading. A quick look at the threading and I didn't have a thread gauge size in inch or metric that fit or I just missed it. I'm sure it wasn't a metric thread and I'm thinking custom threading at the moment. If you recall my lathe is the 9" swing... Now this brings me to a new or revisit the the age of this...
Larry thought the bed from Elgin was around 1930's that's probably correct and the compound, headstock and tailstock was around 1907. Now I did more digging and found on the UK lathe website that Harding made the compound that I have from around 1920-1930 and it was changed some with the glaring difference that this version didn't have the scraped in look as the pre and post 1920-1930 did. So if that's all correct then maybe the gib screw's are also different from what you and Jim have I don't know.
