1NoobMachinist1
- Oct 18, 2023
Hi everyone as the title says, currently I am faced with a challenge and I am not sure how to remedy it. I am currently experiencing some chatter while machining EN24T 110mm diameter shaft that's 660mm long. it us chucked into a hydraulic chuck with cut soft jaws to fit with a tailstock and rotating center. I am using a kyocera DNMG insert with a 0.4mm (CA525) radius I've attempted to use the recommended values after doing the calcs (RPM @ 478, F120, 1mm DOC (2mm overall)) here's the part that stumps me near the end roughly 200mm before reaching the chuck I get a smooth clean finish how ever the other 400mm+ length closer to the tailstock experiences some chatter? What can I attempt to do to reduce this chatter? I will add I've attempted to cut from the back (chuck to tailstock) with a 0.25mm DOC (0.5mm overall) to try and get rid of the chatter marks I'd say roughly 2/3rd of the length comes out smooth but then all of a sudden I start experiencing chatter again. I am pretty new to it and sucks big time to have to machine EN24T (I've machined 304 SS before (16mm shaft) and EN19T (65mm shafts) which after a long battle I got to come out smooth) I attempted to follow the same procedure as I do with the EN19T however I am practically terrified to run the machine at 700RPM with such a big and long piece chucked in.
