Help getting Powermatic 87 back in service
bobbyf
Sep 29, 2022
Hi Guys,
Long time lurker here but this is my first post. I’ve learned a ton and gotten a lot of good advice over the years using the search engine. I’m hoping you can help me out with a 1967 Powermatic 87 band saw.
It seemed to be in good shape when I bought it, I should have looked harder.
The most interesting issue is the lower wheel. It’s a cast wheel that’s supposed to mount on the transmission output shaft with a keyway and lock screws. The wheel itself was cracked (wish I had seen that!) so had to come off. Turns out that the lock crews were missing and the threads were gone on one side like maybe someone drilled them out. Instead of fixing that, I think they took the transmission apart, turned the shaft, added an oversized bronze bushing and pressed the wheel on. It doesn’t make a lot of sense but the bearing on the output shaft looks newer – maybe they were in it anyway?
I brazed the crack in the wheel. It’s 10-20 thou out of round and won’t fit in my lathe. Is that something to worry about? Also puzzling on how to get it back on the shaft.
The rest of my issues are mostly parts. The tranny has a few gears that are worn to the point of being sharp. I can’t find a reference for the gears anywhere.
I’m still trying to cross reference some bearings etc…
I would appreciate any thoughts on the lower wheel situation and advice on parts sources.
Thanks!!
memphisjed
Jan 21, 2019
Memphis
.02 runout out is going to make your saw do a bobbing head or/and make for blade breaking- you also need to tension it as blade stretches.
If you have a mill with a rotary you can true it up with that.
wood2steel
May 17, 2013
georgia
Bobby,
PM me when u get a chance. I have a couple contacts in Tennessee and here in GA that might be able to steer you with the repairs. Have been running Powermatic equipment for 45+ years.
Johnny
bobbyf
Sep 29, 2022
I was worried about that. Unfortunately I don't have a mill that'll take a 20" wheel.
Wood2 - PM sent
reggie_obe
Jul 11, 2004
Reddington, N.J., U.S.A.
If the saw has value to you, it's not unreasonable to have to have the wheel trued, crowned and balanced by a machine shop. May prove to be cheaper than sourcing another used wheel with its own problems.
bobbyf
Sep 29, 2022
How important do you think balance is? The wheel is drilled in several places from the factory balancing. The crack was only a few inches and actually through one of those drill holes. I used a die grinder to create some space around the crack, brazed it then sanded the brazing down smooth. The difference in balance is just the weight difference between the bronze braze and the iron that it replaced.
TGTool
Sep 22, 2006
Stillwater, Oklahoma
If you have the eccentricity you note, you'll also have a shift in mass. Meaning, essentially, that the current center hole is not actually quite on the centerline used when it was manufactured. The gut sense is that the difference in material weight between cast iron and braze isn't material. Since they balanced it initially from the rough casting, if you were to set it up on a mill, indicate the machined rim surface, then bore and sleeve the hole, you should be back to where it started. More or less.
bobbyf
Sep 29, 2022
TG - I may be confused - or confusing. The wheel was cracked at the outer rim where a spoke tied in. The free side of the rim was raised at the crack and had enough movement that the rubber belt was worn away from the area. I've been a hobby welder for over 40 years but haven't done brazing. I was so concerned that the rim would be raised at the crack that I used too much clamp pressure and the rim now has a slight low spot where the braze is. I don't think I changed the center any -just goobered up the rim. A lathe would be ideal but I suppose a jig and a mill would work like someone suggested. Does this sound right or am I missing something? I can send pictures tomorrow...
bobbyf
Sep 29, 2022
Fill in with additional braze material and machine/file back to round?
Or epoxy and new tires. It's not warped - just has the one low spot. I thought about a benchtop jig but never had muck luck doing that type of work by hand. If I can find a machine I should be able to true it up.
richard newman
Jul 28, 2006
rochester, ny
If I understand you correctly, the od of the cast iron wheel is .020 low just in the area where you braised,correct? As far as balance, it shouldn't change much, you haven't lost any iron, just filled in the balancing hole, which might just compensate for moving that part of the rim in .020. I think you could just put a new tire on and grind it true and be pretty ok. You might want to contact Wood Workers Tool Works, I think they can vulcanize a new tire on, grind it true, and balance your wheel.
But you should probably resolve the shaft/transmission issue first. You might want to look at the OWWM site https://owwm.org they also cover metalworking machines. One of those guys might even have the parts you need.
And the sister site http://www.vintagemachinery.org/ will have manuals and parts lists for your saw.
Bill D
Apr 1, 2004
Modesto, CA USA
I read it as 0.002 out of round. That is no problem. You could grind the tires round after install. I would balance the wheel on a simple axle and knife edges. Drill holes at heavy spots and drill and lead wool fill light sections. A car wheel balancer should be able to do this?
BilL D
bobbyf
Sep 29, 2022
Thanks for all the input. I looked on OWWM (already knew about Vintage) and found some interesting posts. I'll definitely look closely there.
I hadn't thought of truing after vulcanizing - that may well be the answer if the shipping doesn't kill the deal.
So - one more question, I've noticed that Delta and others made a similar saw. I don't absolutely have to change the transmission gears but I'd feel a lot better if I could. If several manufacturers used the same tranny it would broaden my search. Anybody have any knowledge on interchangeability with other saws?
