Setting up a WJ200 for a spindle moulder. So far I have it wired up and running on the low speed windings of a dual speed motor and plan to over speed it to get the high speed settings for the machine.
I have the setup wired as a typical 3 wire start/stop with NO/NC respectively.
I have a 3rd switch I want to use as a high speed.
Problem I’m running into is that it seems to be that the speed settings may need maintained switches to retain the speed.
I’d like to have at least one setting other than the standard 60hz setup.
Has anyone done this? How did you set it up?
The switches are on the right.
