HWooldridge
- Aug 29, 2005
- Central Texas
I came across a '68 Hardinge HLVH in very good overall condition. The previous owner's father purchased new, and it was primarily used with a tool post grinder to produce small carbide gages. It was well maintained so is in pretty good shape for its age.
The only two issues I've found are:
- Both the gear range setting and the thread/feed knobs are very hard to move (I have to use channel locks). I'm assuming it's because the shop probably never/seldom used the threading option. Is it normal for these knobs to be so difficult to turn? I opened the side cover and everything appears to be covered in grease from the factory, and of course, it may be pretty hard by now - so I doused everything I could see with penetrating oil. I am able to move the selectors to the right positions but the effort seems excessive.
- The rack has four damaged teeth about 3" back from the spindle nose, so any manual travel over this area makes the carriage jump. I know that normal feeding is done by the motor and threading is done on the leadscrew so I'm thinking the rack is not so important as on other types of machines, but I'd like to make it right. That being said, I was thinking about milling out the damaged area and dovetailing an insert there, then recutting the threads. Or would it be easier to just look for a rack in better shape?
Thanks in advance.
HW
Thanks in advance.
HW
