We had to harden a En-31 shaft with 2" dia and 50" length to achieve a hardness of over 60 HRC.
The shaft had a 2 degree taper for 20" length and a 4 mm pitch Thread for the remaining length. We are not much into heat treatment and upon some little research, we chose induction hardening to avoid warpage since our shaft being too thin for its length. The shaft was hardened all along the taper and heat treater suggested that he would just blacken out the thread portion to some 30 HRC so that the thread wouldn't get too brittle and skin harden the taper portion for 60 HRC.
The application needed some grinding to be done on its taper portion. We had a stock of 0.5 mm for heat treatment + grinding.
After the shaft was hardened, there was a 4 mm bend in the middle. The bend remover suggested that it would break if we cold work it to remove bend. So we had to use a gas torch(neutral flame) to heat red hot and a little stroke on hydraulic ram almost straightened the shaft to run out of 0.3 mm.
Grinding was done and the shaft was well within the specified tolerances. But then , the final hardness test revealed that it is only 28 HRC hard and the part was rejected.
So, Is there any way to rework the part to achieve the earlier 60 HRC? Or if i want to start from scratch, how much allowance must be given for heat distortion? How to prevent bending of such slender shafts during vertical hardening? Any guidelines on where & how to set up support jigs to prevent such distortions?
