With gas springs I used to check tension by simply putting a digital scale on a drill press table and using the spindle rack as a sort of arbor press to press the spring against the scale. Worked great, but gas springs have consistant pressure, such that how far you compress it don't effect the reading much.
So how do you put a number on a regular coiled compression spring ? I've got a small one where it takes 1 oz of pressure to get it started moving a postage scale, 3 oz to move to half it's (at rest) length, and 6 oz to flatten it. So, what is it's "number" for comparison to other springs purposes ?
