Blue Rabit
- Nov 6, 2018
This little backing plate came on the 7 1/2" Van Norman dividing head that I picked up a while back. I think it may be original but I do not have any history on my tool. It has no markings on it at all.
It does appear to visually match the profile of the one in the technical drawing of the 7 1/2 dividing head that is on the vintage machinery site.
I am hoping that someone here recognizes the mounting dimensions and can point me towards a mfg that I can then set up an auction search for.
I have been searching without success to identify the chuck that would have mated to it.
I have been digging through the old catalogues with dimensions for cushman, buck, skinner, and union. I have also reviewed documentation for newer products such as pratt-burnerd and bison.
So far both Cushman and buck are closest but each only has some correct dimensions.
The spindle threads are a 1 7/8-12, not a standard spindle thread so finding a used chuck/backing plate combination is unlikely. I know that it is fairly straightforward to modify the plate that I have to fit another chuck, but that would still leave the mystery.
Dimensions:
OD: 4.25"
Bolt pattern: 3.625" bolt circle, 5/16-24 threaded hole, qty 3 evenly spaced
raised centering boss: 3.125" dia, .11" height
I assume that it should have a 4" chuck on it.
At some point in it's life, someone used a wrench to remove it from the spindle. Other than some scarring from that (which will clean up with a bit of stone work) it is in excellent condition.
The image with colored areas is one I used asking some questions on another site but does show my dividing head. in it you can see the original back plate behind the chuck. There was a very poorly made adapter in between that introduced a lot of runout.
Dimensions:
OD: 4.25"
