I’m rebuilding aKA model335 TVX compressor.I purchased the “kit” that includes what apparently I will need. The entire unit has been disassembled and I discovered in the lower case a needle from a needle bearing. I removed both wrist pins and both pistons to check the needle bearings. Both are okay- in good repair , not missing any pieces. Oponlooking @ the crank shaft and con rods, it looks to me that the rod that holds the larger piston is slightly bent. There is no wear showing in the cylinder wall, on the piston or rod bearing.Is this designed this way? Any help on this would be super, I’m itchin to reassemble and fire it up!
Thanks in advance!, Pumpface1
