Hi all,
I'm currently looking into getting a small injection molding machine to make consumable sandblasting fixtures in bulk. They will be for use inside the company, so I'd like to see if I can make the molds myself. The fixtures could be modified to have draft angles very easily, and ABS seems to be the closest analogue to the PLA+ I've been 3d printing the molds in, but each pair of printed parts takes approx 3 hours. Those numbers are especially inconvenient when I'm being asked for 24 pairs of fixtures, and each individual part has a different sandblast fixture. From my 3d model, the sandblast fixtures are in the neighborhood of 50cm^3 to 70 cm^3.
Would a BOY 50E be a good starting mold machine (76.5cm^3 shot size according to website)? Or should I err toward a larger shot size in case I need a larger part made someday?
We do have cnc machines in the factory as well as a tool room, so simple fixtures in aluminum should be feasible.
Would molding simulation software be worth it?
Is UHMWPE an option for injection molding? The sandblast fixtures were originally machined out of that before I switched to 3d printing in PLA+.
Would I need some kind of plastic pellet dryer to feed the machine from? If so would it be best to buy or design my own?
How do you decide how large to design your ejection pins?
I'm aware injection molding is pretty complex, but I'm also looking at this as a learning opportunity, since my company does do injection molding in a different one of our locations, and it would also be an exercise in machining.
Any info you could give me about getting started would be much appreciated.
Thanks,
Max
Thanks,
Max
