Hello.
I am used to using mazatrol for making my programs. Now im in a situation where I need to use the manual program unit of mazatrol to do some milling.
My problem is that I need to do the milling with B-axis being 130 degrees and mazak has the feature of rotating the whole shape im trying to make as I rotate the turret.
So my question is that is there a way to rotate the b-axis with the xyz coordinates staying in the same direction as normally? Thanks.
