i do believe 6061 is aluminumDiamond coated inserts are for Aluminum and composites only, or I should say, non ferrous materials.
I changed my response since I did not see what material he was using.i do believe 6061 is aluminum
why not DLC?I personally would use coated and polished inserts for aluminum, only NOT the diamond coated.
I don't know man, I get some bars from Kaiser as we all do, then I got some from a local Provo Utah manufacturer, and I gotta say that shite aient T6511i do believe 6061 is aluminum
i have not, worth a shot!Just as a test, have you tried going back over the surface at the same height, no retract, no Z changes, just forward and back.
I have seen this work also, usually on dry, but sill, worth a try.
You can have coated inserts for aluminum that are polished, and you can have plain micrograin carbide inserts that are just polished, no coating.What? polished inserts aren't coated, its either coated or polished?
Not coated and polished, that's an oxymoron?
OK, I don't think I've ever seen a coated and polished insert, I'll take your word for it.You can have coated inserts for aluminum that are polished, and you can have plain micrograin carbide inserts that are just polished, no coating.
Diamond coatings are best used for abrasive materials and extremely long tool life, not necessarily a great surface finish. I tried a Diamond ball endmill in aluminum for finishing a mold core once, ( By the manufactures suggestion) and I got nowhere near the surface finish as I would have using a coated carbide tool meant for aluminum. We keep all our diamond tooling for cutting carbon electrodes and that's it.why not DLC?
definitely room to dial it in a bit more, but huge difference already.
guess those DLC inserts arent worth the ~$40 each that they're selling them for...
Oh, I didn't look up the inserts you were using, I assumed polished.so i got the same insert, just in TF15 grade which i believe is just polished.
24k rpm 100 ipm. .01" on finish pass
Notice
