M.B. Naegle
- Feb 7, 2011
- Conroe, TX USA
One of my home projects is I'm restoring and outfitting an old Boyce Crane Handisaw. While primarily a light duty table saw, they also sold a bunch of different attachments for them making it something akin to an early Shop Smith. Without delving too far into the debates on multi tool machines, mine is missing all of the attachments and I'm happy to reproduce it all from scratch using the old catalog photos for reference, with the end goal of putting some old iron back to work doing small home shop tasks.
One of the primary attachments available was a kit to use it as jointer, utilizing a separate cutout in the table (one of their marketing points was being able to rip and joint without changing setup). The jointer head was a simple arrangement sliding onto a 3/4" shaft and locking with a grub screw (no key). It's a narrow 2" jointer and I can make one if needs be, but I'm wondering if there's something available that can save me some time? Any off the shelf jointer heads in that size? It seems that the standard straight blade heads are frequently for sale as guys upgrade to inserted blades, so I'm thinking about maybe cutting one down. Assuming I go with an old Craftsman, Delta, etc.(?), before I buy something I can't use, how hard are jointer heads typically? In addition to turing down the length on a lathe and chopping the blades to size via radiac saw, I will likely need to bore it out and add a set screw through the side, so if the body is hardened that complicates things.
