kineticmx
- Mar 10, 2014
- United States, CT
Hi gents, my old Nak slant 1 has been getting ran hard lately, and one thing that has consistently been an issue is drilling reliability. Lots of 304 stainless holes from 7/8" to 1.5" using indexable U drills. Seems like no matter how much I dial in the cutting speed/feed and pecking I have chip evac issues. After doing some digging I realized this factory coolant pump is only rated at 180 watts (about 1/4hp) 70 L/min (18 gallons) , and 3M head which is only like 4 psi. (LOL) How big do I go, 1/2HP? It has old coolant lines I would much prefer not to replace, but I will if needed. Even these cheapo Chinese 1/2 hp coolant pumps claim way higher pressure, like 15M head so 5x the pressure. Budget is a few hundred bucks tops. I can probably get away with 1/2hp without having to replace the contactor as well. Last thing: this machine has an external pump not a submersible pump, so I would have to fab a box to sit the pump in if it can't have a line plumbed into it. Maybe someone has something suitable kicking around.
1/2 HP Filtered Lathe CNC Coolant Pump, 3 Phase 220/440V, 150mm (6"), NPT 1" | eBay
Length (flange to bottom): 150mm (6"). It is suitable to driver liquids such as water, coolant, light oil and other clean, non-aggressive matters liquid to cooling or lubricant applications. - Patented design to avoid liquid over flooding.
www.ebay.com
GRAYMILLS MOTOR PUMP 1/2 HP TYPE M.T. NIIAGATA EN50 CNC COOLANT PUMP | eBay
THIS PART WAS REMOVED FROM A NIIAGATA EN50 CNC HORIZONTAL MILL WITH FANUC. NIIGATA EN50 PALLET 091623. is a machine tool and parts dealer located in Southern California. These parts have been dismantled by our own employees from machines at our facility.
www.ebay.com
