Joe Gwinn
- Nov 22, 2009
- Boston, MA area
What I used to use for breaking stuck socket head machine screws loose was a hex bit in a hammer-driven manual impact wrench. The combination of downward impulse plus the synchronized twist usually did the trick. If the socket is already mangled, a one size larger hex bit, ground into a slight taper, may work.
I originally used this for taking SS Philips screws out of aluminum generator housings in a friend's motorcycle. The big downward impulse broke the screw loose from the aluminum. It bade a very distinct crack sound when the screw broke loose.
The damaged-fastener removal bits from post #5 could also be used with the hammer driven impact wrench.
