Guys we are doing part which require to be very flat after parting. Lathe don't have secondary spindle, so we would need to do second operation and that take additional time, so are doing slow part off.
RPM is 600, and first couple of mm I use only 0.01mm/rev, then 0.02 and at 20mm diameter it goes to 0.03mm/rev
This give very flat surface but it is slow, if I play with RPM and feeds, parting is fast but surface finish isn't good at all.
I am using part off insert (TT9080 I think) 3mm wide, holder is taegutec tter 2525-3.
It there some better part off insert primary for aluminum which could allow faster parting but with good surface finish?
Also it doesn't need to taegutec because we need need to buy one more holder
