Hello.
I am from Europe and I recently bought this old magnetic drill, because it was cheap. There is no text left on it, but I have identified it as Black and Decker 741 or 1554. So, 50 years old american drill on 220 volts. It works, did not test only second speed. I started to disassemble it slowly, to clean it and see what has to be repaired. I found the manual, but it does not help me. I am new to these things, so I wanted to ask some questions.
- Do I need to worry about the welded top part of the chuck?
- What kind of grease to put inside the gearbox? Have not opened it yet.
- Can the magnet be disassembled? I do not find how. Maybe this scratched thing on the bottom can be removed?
- Magnet is on 220 volts DC? Or maybe the motor too? Bulbs seem to be 125 volts.
- Is there point to me replacing this old wiring now with something more modern, in case it fails and I cannot find the components? Not sure if I can even find anything now...
- The motor was slowly moving down alone, when it was mounted on the column. This can probably be fixed. I see 2 big and 2 small bolts on the back, where it mounts. The small bolts I think would tighten it more to the column. The big bolts I do not know. The hole of one of them continues on the inner side of the mounting, but the other bolt does not have this.
- Does someone have parts diagram?
