Hello,
I cut a lot of internal threads that are usually for oilfield applications; these sometimes require a blunt start thread or clipped thread. I'm looking to see if anyone has any tips on a go to method for this. Usually its trial and error with some layout fluid until we start to see a scratch, then adjustments are made to achieve the desired result (seemingly stumbling across it) which is quite time consuming.
I run an Okuma LB4000 EXII with an OSP-P300L controller
When clipping, i am using a grooving insert that is .250 wide.
This is a 8" internal 3 acme thread so quite coarse (grooving tool might not be wide enough for good results). I'm using a G71 threading cycle that has been copied over to the grooving tool, with the Z end distance adjusted, as well as the z approach distance adjusted for synching properly (adjusting the cut from the start of the partial thread, usually a multiple of the pitch).
Here is an example of the the threading line:
G0 Z.6
G71 X8.85 Z-3.3 A0. B29 H.3533 D.03 U0. F.333 M32 M75
And the clipping line:
G0 Z.4335 (adjusted to move the initial contact point of the thread)
G71 X8.85 Z-1.1665 B29 H.3533 D.08 U0 F.333 M32 M23 M75
I'm using the M23 auto chamfer pull out as well.
Shouldn't it be as easy as knowing the pullout length (which i believe is the pitch if not denoted by an L value)
Knowing the pitch/lead
Knowing where the thread starts
Adjusting Z start and finish amounts for the desired result?
I feel there should be "simple" parameters based off these values i just cant wrap my head around it haha.
If anyone has any tips or ideas that would be greatly appreciated!
Thank you,
G0 Z.6
Thank you,
