I'm getting a great surface now with the stock geometry, .005" cleanup in wide belt sander to remove all traces. Were you getting resonance with the aggressive cut? I found that having the correct tension on the blade made a huge difference, the scales on most saws are useless, need a tension gauge to get it right. I have to bottom out the spring, and then keep cranking on my Powermatic. The Tannewitz was pretty accurate, what a great saw that was!
I got a decent surface with the 10° standard geometry. I do use a (indicator based) tension gage, and tension to 25,000-28,000 psi. The work surface after the 7°grind was/is so much better, that I routinely grind new blades this way. I'm sure that part of the improvement is due to the fact that the blade is much sharper. To me, it's well worth the time it takes to grind a blade.
Regards
Bob
