-Yes that's exactly what I meant. For about any machine I've ever bought or been introduced to I always wanted to know what it's capable of and what's the current condition. If that meant taking it for a test drive through all the gears, tramming the spindle/quill, and/or comparing "dialed" value to actual value that's what I did before risking a workpiece on an unverified procedure. Heck of a thing to have to tell the boss that the piece is now scrap because "I didn't check it before trying to use it".
I'm not the last word in accuracy and never ran a WEDM (you got that on me) but I worked for a second generation die maker that ran the WEDM to close tolerances. I asked him that same question about blasting the residue and the expected change in dimension. He told me that checking/verifying/recording the change BEFORE the money was on the line was SOP. He did that any time ANYTHING was changed or replaced to ensure a predicable burn. Also said that it should be verified as often as possible (post burn/blast feedback) as an alert to other conditions. That stuck with me throughout my time in the trade.
There are other, more experienced, members that can offer better advice than I can regarding WEDM (Marcus/Implemex comes to mind). I meant no slight or insult in my previous post, apologies if taken that way. I just thought working with tenths would almost demand a check sometime to verify what happens. I don't even trust a surface grinder to take tenths until I've checked temperatures, surface finish, wheel condition, and present size of the work before proceeding. I hate taking chances with expensive workpieces if I can help it. Your initial question was quite valid, my reply was poorly expressed. We ok now?
