I have been practicing on my lathe (11" Logan) and had found some settings that the machine really liked, particularly with a couple of the tools I had been using for roughing. as an example, 2" diameter cold rolled, with WNMG 431 insert 20-30 thousandths cut with a moderate feed rate, and 125-150 RPM. Up until the last couple of days, it always left a great finish, then all of a sudden, nothing but chatter. It will start the cut fine, next to the tailstock, but always starts chattering as it nears the headstock. I have tried a number of different tools, and have been all over the settings, but I can not get rid of the chatter. I have locked the compound, adjusted the cross, pulled the QCTP and made sure there was nothing preventing it from sitting flat. In short, I have checked everything I know to check. My gut tells me the bearings in the headstock, since it always chatters on that end, even when it starts out well, but it runs smooth as silk, and I can detect no movement. I pulled the chuck, cleaned the taper (L00) and re-installed.
I am at a loss where else to look. I am beyond frustrated at this point.
HELP
HELP
