pMetal
- Jul 14, 2014
- United States
We recently installed another used VMC. The machine is only a few years old and had very light use from the previous owner. Runout was near perfect. Overall, the machine was in excellent condition.
We haven't used it yet, but we do home the machine and warm up the spindle every morning.
One morning, during spindle warm-up, the operator reported that the spindle suddenly made a bang sound and thereafter sounded like it was grinding.
The spindle is now very hard to turn by hand. We have verified that the problem is the spindle, not the spindle motor, not the belt, etc.
So clearly we need to get the bearings replaced. But its not normal for a failure like this to happen (fairly new machine, no crash, and failure during warmup), so I'm worried that this might happen again after the spindle is rebuilt.
The machine has a chiller to circulate oil around the spindle housing. Conceivably there was a blockage or other circulation failure, which could have allowed the bearings to overheat. Since we recently purchased (and transported) the machine, which required disconnecting the chiller hoses, it is conceivable that some debris got into the lines, which could have created a blockage. My higher-end machines have a flow sensor to check for this, but I don't think this one has one. We'll investigate the chiller oil flow tomorrow.
The machine also has through-spindle-coolant. We turned this on a few times in the process of testing the machine when we first got it installed. I've read that through-spindle-coolant is hard on spindles, but I don't know why. Is it possible for a seal to fail, which would allow the coolant to get into the bearings? If so, then the coolant could have washed away the bearing grease, which could also lead to failure.
Do you have any other ideas what could have killed the spindle?
