Fanuc Model OI-TFWhich model Fanuc control? Starting a thread at random is most often a bad spindle encoder on a machine with a Fanuc control.
Alright! Thanks a lot!The mix and match use of a GSK motor and drive with Fanuc CNC will make this a more difficult problem to troubleshoot. My collection of 0i manuals stops at the D version. I’ll see if I can find some F version manuals so I can point you to connections to look for a spindle encoder.
I was refering to the variable frquency drive unit. It would be in the control panel and has various settings that will affect the motors behavior.Hi The motor is a GSK GS3000 series model GS3100Y. I've been trying to find the right parameter in it's manual but so far haven't been successful.
I think he should first change the encoder, then observe what happens.Starting a thread at random is most often a bad spindle encoder on a machine with a Fanuc control.
Since he has a GSK spindle drive, the control is most likely using the analog spindle interface so SP-SETTINGS data will be limited. I don’t know anything about the GSK unit, but think it unlikely that it is compatible with Fanuc serial spindle interface.Is it possible it could be a motor to spindle ratio difference?????
I have never tried adjusting this in SP-SETTINGS screen. But they are usually displayed
Brandon
Rather than swap part, it would be preferable IMO, to use an oscilloscope and monitor the signals from the encoder.I think he should first change the encoder, then observe what happens.
He may not have an oscilloscope. Moreover, it may require some expertise to interpret the results of an oscilloscope.Rather than swap part, it would be preferable IMO, to use an oscilloscope and monitor the signals from the encoder.
True that we do not know the tools available to the OP nor do we know their level of expertise. That said, now would be a fine time to spend <$100 on a USB oscilloscope to use with a laptop and learn a little bit about analyzing signals on a simple encoder. A replacement encoder will likely have a >$1000 cost.He may not have an oscilloscope. Moreover, it may require some expertise to interpret the results of an oscilloscope.
Good enough motivation to procure an oscilloscope.True that we do not know the tools available to the OP nor do we know their level of expertise. That said, now would be a fine time to spend <$100 on a USB oscilloscope to use with a laptop and learn a little bit about analyzing signals on a simple encoder. A replacement encoder will likely have a >$1000 cost.
Thats how I have learned. Bit by bit and through mistakes. I tell my younger employees all the time I learned more from making mistakes than any other way.Good enough motivation to procure an oscilloscope.
Learning is bit by bit only, till one becomes an expert.
Actually that's the main issue.. threading is not getting done properly.. every pass starts the threading from a different point and as result forms a new helical..
er... hmmm. missed that.... welp. get to fixing!---------------------
Think Snow Eh!
Ox
Notice
