Waterworks
- Aug 30, 2018
Can this alloy be used for an AR style bolt head and barrel extension with multiple locking lugs for a 5.56 bolt action rifle ?
EN8
Technical Datasheet
Service. Quality. Value.
Applications
• Automotive parts
• Connecting rods
• Studs, bolts
• Axles, spindles
• General engineering components
Product Description
EN8 is an unalloyed medium carbon steel which is used in
applications where better properties than mild steel are
required but where the costs do not justify the purchase of
a steel alloy. EN8 can be heat treated to provide a good
surface hardness and moderate wear resistance by flame
or induction hardening processes. From the automotive
trade to wider general engineering applications, EN8 is a
popular steel in industry.
Chemical Composition (weight %)
C Si Mn P S
min. 0.36 0.10 0.60
max. 0.44 0.40 1.00 0.05 0.05
Engineering Steel
• Unalloyed medium carbon steel
• Reasonable tensile strength
• Can be flame or induction hardened
Mechanical Properties (in "R" condition)
Max Stress 700-850 n/mm2
Yield Stress 465 n/mm2 Min (up to 19mm LRS)
0.2% Proof Stress 450 n/mm2 Min (up to 19mm LRS)
Elongation 16% Min (12% if cold drawn)
Impact KCV 28 Joules Min (up to 19mm LRS
Hardness 201-255 Brinell
Related material specifications
BS970: 1955 EN8
BS970/PD970: 080M40
1970 onwards
European C40, C45, Ck40,Ck45, Cm40, Cm45
Werkstoff No. 1.0511, 1.1186, 1.1189
US SAE (AISI) 1039, 1040, 1042, 1043, 1045
EN8
Technical Datasheet
Applications
• Automotive parts
• Connecting rods
• Studs, bolts
• Axles, spindles
Product Description
C Si Mn P S
min. 0.36 0.10 0.60
Engineering Steel
BS970: 1955 EN8
BS970/PD970: 080M40
1970 onwards
