Hi,
As I know the sub-spindle can be used for transfer from 1 to 2 or SYNCH both ..
I haven't work on sub-spindle before I have got some questions.. I understand that we can manage that by M & G Codes we will use the sub-spindle for below:
1- Transfer from main to sub
2- Transfer from sub to main
3- SYNCH for turning
4- SYNCH for milling
In SYNCH there will be master and slave
1-My question during transferring or synchronization the machine will be on mill or turn mode? or this can happen only in transfer mode (M540 in Integrex) so both mill / turn mode are not existing?
2- Before cancel the transfer mode i need to specify SYNCH them together, transfer one to one .. etc?
3- after cancel the transfer mode I will be able to work either in mill or turn mode with no issue?
4- what are the M228 M328 M229 M329 in Integrex?
Thnaks..
Thnaks..
