VintageIron41
- Dec 13, 2023
Hello and thanks for taking time to read this.
I'm Swiss turning a long part out of H13 steel, app" 10" length, barstock is 3/8', the part has a head diameter app" 1 3/4" from one end, with .250" turned diameters on either side of the head. The problem I'm having is the long cut before the head is warping, the length is 8.250". It was not apparent immediately after machining, but after the parts set for 48 hours the warp appeared. Am using a high positive rake 55dg. diamond tool.
Any suggestions on how to prevent this?
Thank you!
Thank you!
