Need some tooling advice
Need to make some series of parts which have some deeper pockets (110mm)
I can finish the inside with a 20mm ballnose. That's not an issue.
But what's the best way to rough it out?
Material: Aluminium
Should I get a 16mm or 20mm round insert cutter? I've never used those before. I already have a carbide shank for a cutter body with thread.
I don't want to semi finish it after roughing it out. So a cutter with big radius has my preference.
A 16mm long length endmill with 4mm radius would work. But these are quite expensive compared to a insert cutter.
Material: Aluminium
