Toolbert
- Nov 29, 2003
- Vashon Island, WA
We use cast iron 3V sheaves, QD bushed, in a product. They're heavy, overkill, and expensive, but the stock alternative is zinc die cast/setscrew and is not acceptable.
Is there a good reason nobody offers a line of simple plain keyed/setscrew sheaves in 6061 AL? The AL seems standard for timing belt sheaves with similar speed & power ratings, typically with keyed setscrew bores, not taper bushings.
My specific query is two part - is there a reason small V belt sheaves, esp. for 3VX belts, are not common in aluminum? And second, any design guidelines for e.g. bore tolerance, length of bore, number of setscrews?
In house, figure we would blank these in 1-1/4" 6061, be generous with the bore length and hub diameter, and use a long setscrew.
I'd appreciate any design wisdom along the lines of:
- this isn't common because it's cheaper to make a volume product in cast iron
- don't do it, the key/setscrew will fail, even if I think the hub design is overkill
- don't do it, a 3VX belt will wear the aluminum; needs to run in steel or cast iron for a reason
Not doing this to save $ - its more about space and weight.
thanks,
Bob
thanks,
Bob
