I recently brought home Wade 8A #707 from PM member @Halcohead. From what I've been able to uncover, the machine was auctioned by the Navy in 2002 and has seen little use since. Thankfully it was properly prepped for long term storage and everything is covered in a heavy layer of cosmoline. Underneath there seems to be a machine that is still in great condition. I'm starting down the process of brining her back to full running condition.
![2E471897-B35A-47B1-B077-F8AA3F18B481_1_105_c.jpeg 2E471897-B35A-47B1-B077-F8AA3F18B481_1_105_c.jpeg](https://www.practicalmachinist.com/forum/data/attachments/364/364752-b6b8d0f04cf8ddb7580aa7bf0ff06433.jpg)
Over the past few days I've managed to get her converted over to running from single phase 220V with a VFD. This is the original electrical cabinet:
![6914AF09-F0D8-4D67-8AD1-65D305A420C6_1_105_c.jpeg 6914AF09-F0D8-4D67-8AD1-65D305A420C6_1_105_c.jpeg](https://www.practicalmachinist.com/forum/data/attachments/364/364751-394b571ff65cd37a895edd8540721255.jpg)
And converted over to VFD:
![16C19417-569E-468B-BCC9-61B4888D0C97_1_102_o.jpeg 16C19417-569E-468B-BCC9-61B4888D0C97_1_102_o.jpeg](https://www.practicalmachinist.com/forum/data/attachments/364/364753-7382d5852848c5dc31019ef8d7f84fcb.jpg)
The VFD is a 3hp LAPOND K100, mounted in the original cabinet with a 3D printed bracket. So far I'm impressed with this VFD - the documentation and customer support have been excellent and the drive seems to be very fully featured. I was able to use the existing drum switch to control the VFD. The drum switch is connected to a lever on the front of the lathe and is configured to provide the original 3ph reversing contactor with a "run" signal that was closed in both forward and reverse, and then a momentary signal to start the motor in either forward or reverse directions. This mapped directly onto one of the supported control input modes of the VFD making the conversion straightforward.
The next step is to address the rest of the drive system to the spindle. There is a fair amount of noise coming from the variable speed drive. After taking a closer look the belts are toast. After 20+ years of storage they have significant set and deterioration, and I'm pretty sure they were incorrectly sized to being with. Now I'm on a hunt to find the right replacement belts.
Question for Wade 8A owners: what is the correct belt size for the variable speed drive?
The manual shows the same Wade part number for both upper and lower belts (#335), however the countershaft pulley seems to be sized for a 1" belt whereas the motor pulley seems to be sized for 1-1/8". Currently the upper belt is a 1828V370, i.e. 1-1/8" wide, 28 degree 37" belt and seems too wide for the 1" countershaft pulley. The lower belt is unmarked and chewed up but it is about 1" wide and 35" outer circ. It seems to be bottoming out on the 1-1/8" motor pulley.
Could these belts have been inadvertently swapped in the past? I'm also confused about angles for variable speed belts. A crude measurement of the pulleys shows them at closer to 30 deg. Should the angle designation of the belt match the pulley?
Original sale thread: https://www.practicalmachinist.com/forum/threads/for-sale-wade-8a-lathe.419610/
