Hi Everyone.
So forgive me ahead of time for asking about welding procedures. I'm a general machinist operating manual machines. Don't have a lot of experience welding and our welder isn't really open to any ideas I have. Somewhat justified with what I know on welding.
Here's my situation.
We build cylinders for a machine we build. It's a large haybale stacker. Diameters of 2 1/2" - 5 1/2" cylinder tubes.. All 1/4" pre-honed tubing. Distortion of the tube being the issue when welding the port on. We have no engineers here. Just some guys with creative thinking....
Procedure has been to run a tig weld and then follow with a mig weld. The weld is anywhere from a 1 1/2" - 2 1/4" back from the front of the tube. The tube distorts approximately +.015 at the port and of course goes about a -.012 90 degrees to the port. It was recommended to me to carefully squeeze the tube back to a more round diameter in the press. I've had pretty good success at this. Generally get it within .002 -.004 round. But always have to use a flapper wheel heavily to clean up the tight spot at the port area. I've got a batch of approximately 100 cylinders to do. I'd rather not have to do this. I recommended going to just one weld. Well.... he says I'm trying to reinvent the wheel...
So after some fussing he says he'll try it... But only with a tig weld. I don't know why he doesn't want to mig it. He's using 3/32" tungsten but says he thinks he should go 3/16". I'm thinking geez..... Aren't you going to be pouring in a bunch of heat with that size??? The whole idea from me is to get a good strong weld without putting so much heat into the part and distorting it... So again... I'm not a welder. But looking to you guys for tips that I can somehow get this guy to accept and try. My philosophy on life, and work.... is always be teachable. There's always someone with more experience and skill that you can learn from. My pops taught me this. I was an automotive machinist for 23 years and have now been a general machinist for 18years. I'm still learning... Thanks for any help.
