aribert
- Jul 2, 2008
- Metro Detroit, MI
Greetings all:
Lots of background - questions at the end. I sold a 1.5 hp vari-drive J-head motor on eBay a few months ago. Prior to selling, I ran the motor powered by static phase converter & 3 hp idler. Motor ran well (without a load), I took a video of the motor running that was part of the listing. Shortly after the sale,the buyer contacted me and said the electrician could not get the motor to run - I responded by asking the buyer how he was generating 3 phase - radio silence. Now several months later the eBay buyer states that he finally got an industrial electrician to wire it up but the motor has 14 ohm resistance on the windings - the electrician is telling him that the windings should have 2 to 3 ohm. Message below.
"After a lengthy process in finding the right electrician, we just hired an industrial electrician who specializes in heavy equipment machine shop repair. The motor you sold us has 14 ohms on each winding set. The original motor has 2-3 ohms per winding set. The motor we bought from you does not start up and there is 3 phase power. Same connection, the old motor starts up no issue (has bearing noise which is why I wanted it replaced).
The electrician stated that your motor has unusually high ohms and since it will not start up is bad."
I am fairly confident I sold the buyer an good motor. Reading between the lines, I am guessing the first (presumably residential electrician) hooked the motor up to 220 single phase. How likely is it that they fried the motor on single phase? What would a typical resistance be between windings on a 1.5 hp 3 phase motor? BTW, I pulled out a 1.5 hp 3 phase fan motor I had laying around (have never powered the motor up) and the resistance between windings runs 4 to 4.3 ohms.
