charlieman22
- May 4, 2021
Am mid restore on my 10EE.
Have had the apron on and off a handful of times as I work to get everything nicely fit and oil system properly pumping.
Had to rebuild one end of the arm due to wear.
Added a bit too much material to it and found some binding as the spring inside the lever's plunger was getting completely compressed.
Removed a bit of material and the pump is now working nicely.
Found that I get some leaking through a bolt that holds the half nuts, here:
Is this normal?
Appears this hole is tapped right into the oil supply line.
Seeing the system working now - not fully convinced about the feed to the ways.
Perhaps it will improve with any air worked out of the system.
Was surprised by how many revolutions are required by the feed rod to get a single pump cycle.
Hand wheel must be 4 or 5:1 more?
Will run and keep an eye.
Is this normal?
