Kiwi-Turret
- Sep 8, 2022
Hi All,
Just after a small bit of clarification (have electricians coming next week so will re-confer with them also) as owners of property asked my advice on some equipment they want to install which lead me down a rabbit hole and i forgot how things work (have a brain injury so when i get overwhelmed it turns into a mess unless i get a clear answer)
Current setup - x3 240v Single phase connection (rated @ 60amp) - Mains line to house only supports 40amp per phase (but have been told multiple different stories by contractors and lines men)
Changing to 400v 3 Phase 40amp connection (wanted 60amps but electrician wouldn't approve, so will seek written confirmation when they are onsite to do work, as if i intend to stay onsite i might have to pay for an upgrade i wanted to do years ago but got conflicting stories...So brought a 40kva gen that worked until i let someone use it and they overheated the engine)
Two questions:
1. Does a 3 phase motor rated at 15amps pull this per phase (i was told it was Divided by 3 due to the 3 phases, but i was under assumption it is 15amps across the 3 phases as the 3 phase supply only made it more efficient)
2. If above answer is 15amps across the supply(3 phases) and not say 5amps per phase, Then considering the house oven/garage/heat pump/hot water etc are still on single phase that even when it is balanced i have to take into consideration the total amount of load per phase... Example 15amps (3 phase motor on lathe) + Single phase 15amp heatpump. Would that be 30amps on one phase + 15 amps per the other two.
I am going to look into options to reduce start-up current like VFD's etc if required.
Hopefully someone can answer this in simple terms (like i said i will have electricians give written responses so owners have a copy) - Sadly if i had done the conversion few years back i could of had mains + 3 phase conversion done for less than the price of just the conversion.
Thanks
Two questions:
Thanks
