twistedmetalman
- Dec 28, 2006
- Franklin, MA
OK, I am trying to twist 2" thin wall square tubing but no matter what I've tried thus far the tubing collapses on me (usually at either end) before I can get a twist of any significance. I've tried packing the tube with sand and welding the ends closed, tried a pipe down the center, tried it cold (which would be my preferred method) and tried it hot with the same results.
Someone mentioned to me that I may not be using the right type of steel which may be causing the problem. Does square tube come in different grades and if so any advice on the type I should use or any other ideas on how to get the twists without it collapsing.
Beers,
Beers,
