Gloryrates500
- Jan 5, 2019
- Cologne, Germany
After running a program, the vice was blown off with compressed air to clean it to insert a new raw material.
The mechanical probe was exchanged for the Z zero point and the Z axis was zeroed in the "Preset".
When the program, which had already run 22 times, was started again, the Z axis moved into the work piece at rapid traverse where it was in X and Y
The program should actually have run on X/Y coordinates outside of the work piece
Greater damage could be prevented by reacting carefully to the pots.
quill raised to free the cutter
it is always good to extend the quill a bit so that you can free the milling cutter from an awkward situation if the worst comes to the worst
after that, it was no longer possible to change the operating mode or make any entries either on the keyboard or on the soft keys etc.
keyboard frozen.
Q1/Q2 off
main switch Q1/Q2 actuated
self test green OKs and no errors
segment display NSV 0.0
D11 indicator diodes green
drives can be switched on
jog axes with the keys (X/Y/Z) normal
Operating mode 1 , F8 "Continue" for reference travel ........ without reaction
also otherwise no operating mode change or other inputs via keyboard possible
all axes can be moved via keys......
Q1/Q2 switched off
terminal opened
visual check for any problems with a lamp ....... negative
no broken cable and no suspicious spots on the NBP board....
NBP board replaced
checked the seat of the ribbon cable to the keyboard
operating mode 1 , F8 "Continue" for reference travel without reaction
also no operating mode change or other inputs via keyboard possible
called Martin......
he first reminded me that "compressed air" at CNC machines is very bad - almost a reason for termination!!!
casually looked at the keyboard during the call and noticed that the Z key on the keyboard seemed to be pressed!?!
a 42CrMo4 chip is stuck in the keyboard so that the "Z" key is permanently pressed?!?
the last thing I did was to press the Z button for the new Z zero point....
chip removed aaaand.....
the machine works perfectly again immediately
laughed heartily with Martin
notice- compressed air is veeeery evil
and check if a key on the keyboard is stuck. it seems to have a big impact....
keyboard frozen.
Q1/Q2 off
Q1/Q2 switched off
terminal opened
NBP board replaced
called Martin......
