Hi again pcm81:
Yeah, I get what you're saying but consider this:
I can turn parts completely unattended from a 12 foot bar and my bar feed time from part to part is measured in seconds or fractions of a second.
My material is consistent, my workholding consists of a 40 dollar collet from the collet store, and I can turn within tenths.
I can buy the whole bar for 50 bucks and make ten grand worth of parts from it (if I have the right parts to make!
I can load the bar, push the button and walk away until the magazine of bars is empty. (well almost...things still break and fuck up and etc etc)
If I had a Willemin Macodel, I could do the same thing with complex milled parts.
I'd get them dead nuts accurate.
I'd get net shape parts from one machine in one chucking (plus a subspindle operation) completely autonomously and very fast.
My Whippo Zippo Willemin would cost about the same as a DMLM printer from Eos but I could do so much more productive work with it and it would be faster, more energy efficient and would make better parts too, with less maintenance, no special fire proof structure, no special material handling facility etc etc..
My customers could choose any material that can be machined and I could certify the material to meet customer specs for chemistry and physical properties simply by my material ordering choices.
Something you must realize (if you're not already experienced with it) is that near net shaped parts that need to be finished on only some surfaces are a right royal pain in the ass by comparison.
Doesn't matter if they're castings, forgings or 3D prints.
They're hard to hold onto, hard to establish consistent datums for, and hard to fixture consistently.
Automating a process for handling and machining them is harder and more expensive...usually by an order of magnitude.
When a near net shape preform is useful, is when most of the features do not need to be all that accurate, and when a ton of material would have to be removed from a billet, when you can get better physical properties from the preform (like the strength from a forging for example) and when the internal geometry of the part doesn't lend itself to machining it.
Automating workholding and a machining process for a near net shape part is a major challenge that billet parts do not suffer...there's always something to grab onto until the very last operation, and when you can feed a bar, you gain efficiency and cut your labour costs while making more and better parts.
So yeah, 3D printed parts can slide into a place where castings maybe used to live, but they won't transform the metalworking industry...if anything, they'll augment it.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
