miyano_cnc
- Jul 29, 2022
Bump to the top, any ideas?
I don't, and haven't been able to find one online/ebay/etc..Do you have a parts book for this machine?
I don't know, the compressor seems to have been sold a while ago. Was just mentioning it in case it 100% was needed.You said there's no air to the machine. Are you positive it's not needed for the tool change?
Good to know, will do that next time.On the screen with the ladder diagram, there should be a soft key you can push to switch the display mode so that it shows the addresses, not what they're labeled
I don't, same problem as the parts book. I have the parameters, atc, schematic, ladder diagram and M codes.Do you have a maintenance or operator manual with the machine?
The same position as last time, Z=140.00When you changed 1300, bit 2, you said it just sat there. How far did it get?
there isnt any air to this machine? uh how is it not tripping a low pressure alarm? haven't seen a machine yet that hasn't needed air for the ATC. most are used to actuate the rotation or at least the release of the clamp in the spindle which needs to happen first before a tool change.I don't, and haven't been able to find one online/ebay/etc..
Thanks for the help, at this point I'm just going to have to accept that it won't get fixed until after I move it to my place and run power to my garage. I would assume around Oct/Nov ish hopefully. I'll revive this thread at that point.
No air and no low pressure alarm. Hence why I mentioned it to see if it had anything to do with the tool arm position alarm.there isnt any air to this machine? uh how is it not tripping a low pressure alarm?
Notice
