Best way to remove and clean cutting oil from sump
Whetstone
Mar 27, 2011
Providence RI
I just bought a horizontal mill and want the replace the cutting oil (which smells like motor oil) with a water based coolant. I can use the pump and a vacuum to remove most of the oil from the reservoir, but what is the best way to clean the sump and lines in preparation for coolant? Fill the sump with a solvent and run it through the system? If so, what solvent? Are there other options?
DDoug
Oct 18, 2005
NW Pa
Try diesel fuel or kero as a solvent, nothing stronger/more flamable.
Afterwards, the off the shelf alkaline cleaner should remove the solvent.
andrewmawson
Jan 9, 2003
UK
When I've cleaned 'orrid coolant tanks I've always used sawdust - pile it in, stir it around to absorb the oil and water, and then vacuum it out. Obviously taking care to avoid pipe lines etc.
