jellywerker
- Mar 26, 2016
I'm working with a fabrication shop that occasionally has need for better CNC capabilities than our Trak bed mill, but we're not quite sure where to start with machine selection.
In some instances it makes sense to outsource, but typically we need more control over timeline and part flow than we can get with an outside vendor. Maybe if we had more consistent volume machining work and were able to develop a close relationship with a shop, but those aren't our circumstances.
A typical situation is that a job with more machined components than typical will come though, get final approval, and then we'll need parts on the floor to start integrating into our work within the next week or so. We don't usually have the luxury of having full approval 6-10 weeks prior to needing to start fabrication.
We have a good machinist who will be able to learn and operate anything we bring in. We have 60-100 square feet we can allocate, adequate power, compressed air, etc...
The question is what type/models of machine to keep an eye out for? We'd be looking to buy used since our usage is very spiky - a few times a year it will pump out parts for a few weeks, the rest of the time it will probably sit idle.
The main requirements are 40 taper spindle so we can use our current toolholders, and a toolchanger. Other than that, we're flexible. The parts we'd want to run here are aren't huge or very complicated. The tolerance requirements aren't high. What we don't want to do is spend too much time and money making an old machine reliable. We don't need a project.
I'm leaning towards a Haas VF1 or similar from the last 10-15 years. If there's something a bit more compact and likely to be available for a similar price range used, I'm open to alternatives. I don't want something too special or uncommon. Budget is between $10-30k for the machine and transport to our shop. Not concerned about additional expenses for tooling and such.
