As in the title, im running a two turret doosan puma. And i cant get the spindles to run. If i run in sync they run? (IE s100 m213)
G97s100m3p11 or s100 m3 none of that works.
So this problem comes after changing out the spindle liner, changing the collet, im using royal precision collets, i changed the position on the sensors trying to do everything according to the POORLY written book. Ive moved the sensors in every which way you could possibly think to move them to make sure that that wasnt the issue but who knows. The machine also has a bar feeder, with no errors and was in manual operation. So far ive tried removing the liner, going back to the collet that was im before i changed things, sensors in everywhich way. To be clear on the chucking sensors, open the P1 sensor light is on, closed nothing is on, and doesnt even flip P2. My chuck switch is set to clamp the OD and lights up when closed. Ive tried running the program that was just running in the machine. Nothing i do gets this spindle to budge except syncing up the main and the subspindle. Machine was running just fine yesterday. Could this be an issue with a breaker? I dont have the key to access it to check. Could it be the tool setter? I did just use it? Is it possible for the sensor on the setter to silently fail? Ive tried power cycling the machine, and that didnt do anything. Maybe the better question is what conditions need to be met for a single spindle to turn on?
