Hi all
I just bought FP3 (1983) with Heidenhain DRO and Labod circuit inside.
I think it is FP3 Aktiv.
The problem is, this heidenhain is broken, the lights are on, but the 7 segment display doesnt come out, and its S/N also been gone --- i dont know how much it costs to repair it.
i think will replace the heidenhain with general DRO.
second problem is, it only can generate constant speed of axis, and i believe its a rapid feedrate, feed selector (potentiometer is not working).
Can i replace original heidenhain with common DRO available on market?
what is the cause of constant feedrate? is it because the potentiometer? i check the existing potentio (R1V) is on 10k ohm, is it the correct one or not? i did search the internet and i can not find the correct spec for R1V potentiometer in deckel wiring diagram.
thank you and waiting any advise from all of you
