Peter from Holland
- Jan 15, 2005
- The Netherlands
We have this FP3Active all cleaned up
But we ran into a problem while testing it
The powerfeed Z-up jumped out of engagement every time
So we took off the saddle
Easy enough if you have done it several times already
Disconnecing the scale on the X is the most troublesome
It has to be desoldered or the cable pulled through the hoses to the DRO
We decided to desoldered it
Then DRO on the Y needs to be removed as the Y slide has to go fully back out of the spindle
Some scrapers and bellows removed
Gib plates loosened a bit
Take the bolts out of the nut of the Z-spindle
After this picture we decided to strap the base of the machine to the pallet as all weight is on the back without the saddle and we do not want it to tip over
Some straps and the forklift make it come out Gently
Th
All straigt forward sofar
Layed it down on a trolley and opened it up
We noticed that it was tampered with before All the grease made that obvious
After further inspection we noticed the sliding gear that engages the feed Z up hardly could engage with the mating gear as it would slide in the bushing visable on the last picture
Th
