GrantGunderson
- Jun 4, 2021
- Bellingham, WA
Here are the various aligment marks in relationship to each other. Notice the "V" that was top center when I pulled the spindle from the headstock is close but not aligned to the factory bearing alignment marks. There is another short aligment mark on the front that does align with the "V". I also found a "T" on the backside of the Spindle flange, so guessing this is a fitters mark from hand fitting the front spindle retainer to it.
On the reverse side of the spindle is a paint splotch... looks like the original paint from the inside of the head stock and another fitters mark.
Here is the alignment mark for the inner race. The outer race mark, according to my research is the high point for the bearing. One of my Front Duplex bearings had a "12XX" on it. This matches the rear spindle bearing and I believe that is the amount of eccentricity the bearing has, so the factory installed a full match set of Front spindle bearings and rear spindle bearings. However, I have reason to believe one of my Front Duplex bearings was replaced at some point at has a "13XX" so seems like they tried to match it as close as possible..... Interesting.
The front Spindle bearing retainer plate, had what looks like a ton of extra gasket compound that was blocking most of the front oil labyrinth seal and ports. So Glad I took it apart to clean it.
