I'm new here, not a machinist yet, and getting ready to buy my first lathe, a 1942 RP 14x30 with U.S. Navy stamp. I wanted old American iron, and this seems to fit the bill, but for reasons below I'm struggling with a $4250 asking price.
Lathe was 'donor' machine on a WWII repair barge, and evidently saw very little use in the war and since. When owner got it, he disassembled, cleaned, painted, reconditioned. I inspected: headstock gears appear new and not even worn in, ways look good (no wear except minor galling in a few places), under power (240, new single phase motor). When powered, all spindle speeds seem to work perfectly. Manual carriage travel and cross slide are butter smooth. Comes with 3- and 4-jaw chucks, tailstock (smooth operation, bore pristine), drills, reamers, HSS blanks, QCTP, tool holders, and drill chucks. Missing change gear cover. A taper attachment is missing the bed clamp. Compound is missing hand crank. I found a replacement for each of these on another nearby lathe. No steady or follow rests.
Main issues that I found: feed rod didn't engage (via "castle nut clutch plate"), so I worked with seller to re-establish feed rod power. Power cross slide then worked, but longitudinal feed still did not, we suspect from a sheared key or pin in the apron. Should be straightforward fix, I believe. Assuming success, the lathe should be at 100%.
Question: with these facts in mind, is the $4250 asking price reasonable for the lathe and tooling package? If not, what would be more reasonable? (N.B. I walked away from a 1945 RP (same size; less tooling) at $1000 because some head stock gears were chipped and missing teeth -- beyond my current ability to fix.) Any facts that I'm overlooking?
